Most recent update: 2014-06-02
3D modeling( Designing / Simulation ) |
Company name |
有限会社 大里化工 (Yuugenngaisha oosatokakou) |
Website URL | http://www.uclid-f.com |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 76803 |
Type of manufacturing | Stationery products / Leisure goods / Home electrical appliances |
Large | Medium | Small |
Designing | Mold designing | Injection molding die 3D modeling (plastic) |
Designing | Product and part designing | Model designing External design |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Lathe machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Chassis manufacturing Sheet metal protocol manufacturing Coating |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Fused Deposition Molding (FDM) Powder sintering Model manufacturing Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining 3D modeling Blanking die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Mold base machining 3D modeling Injection molding die Blow molding die Vacuum/Air pressure molding die Extrusion molding die Insert molding die Below 60 t 60 - 300 t 000 t 000 t and over Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Die manufacturing | Rubber mold | Designing Rubber mold part processing 3D modeling Packing-related products |
Die manufacturing | Spring mold | Designing Manufacturing |
Die manufacturing | Forging die | Designing Manufacturing |
Die manufacturing | Casting die | Designing Manufacturing 3D modeling |
Mass production | Plastic | Insert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) Elastomer Injection molding Handles small-scale production |
Surface treatment | Plating/Chemical conversion treatment | Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic |
Surface treatment | Coating | Air-spray coating Resin coating Acrylic coating |
Surface treatment | Printing and others | Silk screen printing Hot stamping (gold embossing) |
Assembly/Inspection | Assembly | Toy and sundries assembly |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Plastic |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Screw manufacturing |
