Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Powder coating( Surface treatment / Coating ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Transportation equipment manufacturing( Product manufacturing / Others ) |
Company name |
田中産業 株式会社 (Tanakasanngyou) |
Website URL | http://www.tanaka-sng.co.jp/ |
Street address |
Shizuoka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 68 |
Annual sales | Unregister | EMIDAS Member Number | 76676 |
Type of manufacturing | Machine tools / Industrial machinery / Office appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Coating Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Corner shearing CO2 laser machining Laser marking Nitrogen cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Mass production | Metal press | Bending Blanking Iron Plated steel plate Thickness Single press (below 80 t) |
Surface treatment | Plating/Chemical conversion treatment | Parkerizing (phosphate film) Iron Black oxide finish Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Powder coating Electrostatic coating Melamine coating Metal coating |
Assembly/Inspection | Assembly | Office equipment assembly Industrial machinery assembly |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Machine tool manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
