Tapping( Development and production of prototype/Small-scale production / Machining ) |
Part processing( Die manufacturing / Press die ) |
Wire machining( Mass production / Mechanical processing ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
CO2 welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Lap polishing( Surface treatment / Lap polishing ) |
Company name |
中辻金型工業 株式会社 (Nakatsujikanagatakougyou) |
Website URL | http://www.nkk-24.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 20 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 76483 |
Type of manufacturing | Home electrical appliances / Electronic parts / Lighting equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die 3D modeling (press) |
Designing | Data creation (3D scan) | 3D printer Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Rolling Iron Stainless steel Aluminum alloy Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Sheet metal protocol manufacturing Angle machining Coating 3-roll bending |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Shaving die Progressive die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining Wire machining Iron High precision |
Mass production | Welding / welding | CO2 welding TIG welding (argon welding) |
Surface treatment | Lap polishing | Lap polishing |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly Industrial machinery assembly Toy and sundries assembly |
Parts manufacturing | Machinery part | Mechanical parts |
