Most recent update: 2022-05-31
Screw manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Company name |
株式会社 草加ネジ (Soukaneji) |
Website URL | http://www.sokaneji.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 45 |
Annual sales | Unregister | EMIDAS Member Number | 76045 |
Type of manufacturing | Construction material / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Development and production of prototype/Small-scale production | Machining | Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Thread grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Single press die 60 - 300 t |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Mechanical processing | NC turning machining Tapping machining Complex turning machining Wire machining Rolling machining Screw cutting machining Electrical discharge machining Iron Stainless Aluminum alloy Titanium alloy Automatic screw machining |
Mass production | Welding / welding | TIG welding (argon welding) Arc welding |
Surface treatment | Plating/Chemical conversion treatment | Iron Copper Brass Aluminum Stainless steel Titanium |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Screw manufacturing |
