Most recent update: 2017-08-31
Company name |
株式会社 朝日製作所 (Asahiseisakusho) |
Website URL | http://www.asahi-metal-dept.co.jp |
Street address |
Yamaguchi Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 75 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 75580 |
Type of manufacturing | Industrial machinery / Transportation equipment / Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing |
Designing | Industrial equipment designing | Industrial machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Keyway milling Shaper machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Drawing die Bending die Blanking die Forming die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Plated steel plate Stainless steel material for spring Nickel Thickness Thickness |
Surface treatment | Polishing/Lapping | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Industrial machinery assembly |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Vacuum equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing |
