Most recent update: 2018-12-13
NC turning machining( Mass production / Mechanical processing ) |
Company name |
株式会社 平川製作所 (Hirakawaseisakusho ) |
Website URL | http://www.hirakawa-in.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 60 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 75331 |
Type of manufacturing | Machine tools / Heavy electric machinery / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Centerless grinding Thread grinding |
Mass production | Metal press | Stainless steel |
Mass production | Mechanical processing | NC turning machining |
Surface treatment | Plating/Chemical conversion treatment | Tin (barrel) Solder (barrel) Zinc (barrel) Chromate (general) Gold/Silver plating Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Other anti-rust treatments Hard chromium (rack) Degreasing |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Heat treatment | Vacuum normalizing Annealing Stress relief annealing (SR treatment) Vacuum annealing Quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) Coating Shot peening/WPC Buffing Shot blast Sound blast Glass beads blast |
Parts manufacturing | Machinery part | Gear manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
