Automobile (mass production)
Electronic parts
“Gas-tosu” Gas venting pin for measures to the defects which occurs with gas in plastic injection molding
We have several type of Gas-tosu:
Ejector-pin type, Core-pin type, Screw clamp type, Plate type, Split pieces combination type, etc.
We have prepared the various types of Gas-tosu to fit into the various uses.
It is very important to vent gas in plastic molding.
Various problems in plastic molding can be solved by doing gas venting
The effects when using Gas-tosu
1. The frequency of the maintenance decreases because die does not get dirt, so the man-hour for maintenance can be reduced.
2. Low pressure molding becomes possible, then burrs will be reduced.
3. Clogging of gas vent in Cavity becomes difficult, then short shot can be prevented.
4. The defect rate is improved, then man-hour for inspection can be reduced.
It is expected that we can achieve improvement in the quality and the productivity also a cost reduction at the same time!
Company name | Plamoul Seiko Co.,Ltd. | EMIDAS Member Number | 74952 |
Tomiya City Miyagi Japan |
Telephone number | +81-22-348-1250 | Fax number | +81-22-348-1244 |
Employees | 70,000,000 JPY | Annual sales | 320,000,000 JPY |
Employees | 42 | Person in charge | Fumitomo Kikuchi |
Type of manufacturing | Jigs and tools / Electronic parts |
