Most recent update: 2022-07-04
Tantalum( Material / Specialized material distribution ) |
Kovar( Material / Specialized material distribution ) |
Molybdenum alloy( Material / Specialized material distribution ) |
Company name |
株式会社 クラフト (Kurafuto) |
Website URL | http://www.craft-metal.com |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 6 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 74349 |
Type of manufacturing | Jigs and tools / Electronic parts |
Large | Medium | Small |
Material | Steel component distribution | Shaped stainless steel Stainless steel spring Stainless steel pipe |
Material | Specialized material distribution | Kovar Molybdenum alloy Tantalum |
Material | Nonferrous metal distribution | Flat steel plate Steel (round) bar Copper and brass products Titanium Nickel Pipe material Others |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Straightening Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Keyway milling |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Internal grinding Centerless grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Photoforming Punching Welding Bending Small-size prototype manufacturing |
Mass production | Metal press | Drawing Bending Blanking Iron Aluminum |
Mass production | Glass/Silicon | Spherical lens |
Mass production | Forging | Header machining |
Surface treatment | Plating/Chemical conversion treatment | Chromium (barrel) Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Alumite (anode oxidation) Electroless nickel (rack) Aluminum Other anti-rust treatments Titanium |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Other surface treatment | Vacuum deposition Spattering Teflon coating Buffing |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing |
