Telecommunication equipment
Semiconductor
Medical equipment
【High-quality projects such as chambers for inspection equipment are processed in a constant temperature room.】
This is an example of manufacturing a chamber for inspection equipment in a constant temperature room.
Chambers for inspection equipment, which are required to have high quality, are manufactured in temperature-controlled areas to provide safety and security.
〈Material》
・Aluminum A6061
〈Processing method》
Horizontal machining center (PFH4800 manufactured by Yamazaki Mazak Corporation)
<Characteristics>
・Manufactured for inspection equipment
・Size 90 * 200 * 220 mm
・It is also possible to handle the sealing surface of the O-ring.
・Sub-ASSY such as pin press-fitting and helisert insertion is also performed.
<See other processing examples>
waterproof housing
https://en.nc-net.or.jp/company/73752/product/detail/164425/
🌸With abundant equipment, Sacra-Tech performs a wide variety of processing such as 5-sided processing and small-diameter tap processing with high accuracy. Please feel free to contact us 🌸
SACRA-TECH CO.,LTD.
Sales department
Yoshio Watanabe
yoshio@sacra-tech.co.jp
Company name | Sacra-Tech Corp. | EMIDAS Member Number | 73752 |
Sirakawa city Fukushima Japan |
Telephone number | +81-248-28-2126 | Fax number | +81-248-28-2570 |
Employees | 35,000,000 JPY | Annual sales | 935,000,000 JPY |
Employees | 65 | Person in charge | SACRA-TECH CO.,LTD. |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment | ||
Primary clients |
