Most recent update: 2021-05-18
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 アジャスト (Ajasuto) |
Website URL | https://www.adjnet.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 12 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 73476 |
Type of manufacturing | Industrial machinery / Transportation equipment / Medical equipment |
Large | Medium | Small |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Broaching Keyway milling Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Small-size prototype manufacturing |
Mass production | Rubber | Rubber product prototype manufacturing and other auto parts binoculars and optical products Home electrical appliances Mobile phones Medical |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Electroless copper (barrel) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Titanium Black oxide finish Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Shot peening/WPC Buffing Shot blast Sound blast Etching (surface treatment) |
Parts manufacturing | Machinery part | Vacuum components manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing |
