Most recent update: 2023-07-21
Hydraulic counter pressure press( Mass production / Metal press ) |
Company name |
フジイコーポレーション 株式会社 ダイレスプレス事業部 (Fujiiko-pore-shonn dairesupuresujigyoubu) |
Website URL | https://www.e-fujii.co.jp/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 12,000,000 JPY | Employees | 113 |
Annual sales | Unregister | EMIDAS Member Number | 72991 |
Type of manufacturing | Industrial machinery / Transportation equipment / Lighting equipment |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Designing | Simulation | Press |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Corner shearing Thin plate (below 6 mm) Stainless steel 3D laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Profile grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Arc welding Robot welding Brazing Stud welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Single press die Press robot die Below 60 t 60 - 300 t Over 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Thickness Thickness Hydraulic counter pressure press Single press (200 - 500 t) Single press (500 t and over) |
Mass production | Mechanical processing | Machining NC milling machining Iron Stainless Casting |
Assembly/Inspection | Inspection | Metal press |
