Punching( Development and production of prototype/Small-scale production / Prototype processing ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
60 - 300 t( Die manufacturing / Press die ) |
Leaf spring( Parts manufacturing / Spring ) |
Carbon steel( Parts manufacturing / Spring ) |
Stainless steel( Mass production / Metal press ) |
Company name |
合資会社 笠原スプリング製作所 (Kasaharasupurinnguseisakusho) |
Website URL | http://kasahara-spring.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 500,000 JPY | Employees | 2 |
Annual sales | Unregister | EMIDAS Member Number | 72946 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Die manufacturing | Press die | Bending die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Stainless steel material for spring Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Mechanical processing | Tapping machining Iron Stainless Aluminum alloy Copper alloy |
Surface treatment | Plating/Chemical conversion treatment | Nickel (rack) Chromium (rack) Nickel chromium (rack) Acid pickling Iron Other anti-rust treatments Unichromate (white) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Barrel finishing (rotation) Buffing |
Surface treatment | Heat treatment | Quenching Carburized quenching |
Parts manufacturing | Spring | Thin leaf spring Leaf spring Conical spring Spring washer Carbon steel |
