Most recent update: 2010-01-16
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 阿部製作 (Abeseisaku) |
Website URL | http://www.abeseisaku.co.jp/ |
Street address |
Gunma Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 40 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 72583 |
Type of manufacturing | Home electrical appliances / Transportation equipment / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring 3-roll bending Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Manufacturing |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Aluminum Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Powder coating Electrodeposition coating |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Precision equipment assembly |
