Most recent update: 2023-09-28
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 玉吉製作所 (Tamayoshiseisakujo) |
Website URL | https://www.tamayoshi.co.jp/ |
Street address |
Shizuoka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 65 |
Annual sales | Unregister | EMIDAS Member Number | 72254 |
Type of manufacturing | Machine tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Perforated metal Expanded metal Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Chequered plate Flat steel plate Steel (round) bar Seamless steel pipe Welded steel pipe Drawn steel pipe |
Development and production of prototype/Small-scale production | Machining | Tapping Machining/Handles small-scale production (order from 1 piece) Iron Aluminum alloy Magnesium alloy Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring Coating 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Fiber welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Mechanical processing | Tapping machining Iron Stainless Aluminum alloy |
Mass production | Sheet-metal processing | Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Laser and turret punch punching CO2 laser processing Fiber laser processing Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting |
Mass production | Welding / welding | CO2 welding Fiber welding Spot welding TIG welding (argon welding) Robot welding Stud welding Condenser spot welding |
Surface treatment | Plating/Chemical conversion treatment | Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Zinc (rack) Alumite (anode oxidation) Electroless nickel (barrel) Chemical conversion coating Iron Brass Aluminum Stainless steel Degreasing |
Surface treatment | Coating | Powder coating Electrostatic coating Melamine coating |
Surface treatment | Printing and others | Silk screen printing |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Mechanical parts |
