Complex turning machining( Mass production / Mechanical processing ) |
Automatic screw machining( Mass production / Mechanical processing ) |
Handles mass production( Parts manufacturing / Electric board and electronic part ) |
Shaft and roller manufacturing( Parts manufacturing / Machinery part ) |
Other electrical part manufacturing( Parts manufacturing / Electrical part ) |
Optical parts manufacturing( Parts manufacturing / Machinery part ) |
Screw manufacturing( Parts manufacturing / Bolt/Screw/Nut ) |
Company name |
有限会社 佐久間製作所 (Sakumaseisakusho) |
Website URL | http://www.sakuma-ss.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 7 |
Annual sales | Unregister | EMIDAS Member Number | 72063 |
Type of manufacturing | Medical equipment / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Keyway milling Automatic lathe Bench lathe machining Router machining Lathe machining (resin) Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Magnetic Abrasive |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Mass production | Mechanical processing | NC milling machining NC turning machining Tapping machining Complex turning machining Screw cutting machining Micro-hole machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Automatic screw machining Turning machining(plastic) Titanium |
Mass production | Plastic | PEEK (polyetheretherketone) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Brass Aluminum Stainless steel Other anti-rust treatments Titanium Colored alumite |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Vacuum components manufacturing Connection parts manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing pipe manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing Switch manufacturing |
Parts manufacturing | Electric board and electronic part | Protocol and small-scale (PCB) Handles mass production Handles short delivery |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Blade manufacturing |
Auto parts manufacturing | Drive system part | Brake parts |
Auto parts manufacturing | Interior part | Communication accessories Audio components |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Pipe connection Water supply and discharge system manufacturing Construction machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Surgical instruments Inspection and testing devices |
Product manufacturing | Household commodity | Office equipment manufacturing Outdoor leisure product manufacturing Storage products |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking |
Product manufacturing | Food industry machinery manufacturing | Other food industry machinery manufacturing |
Product manufacturing | Watch/Glasses/Accessory/Jewelry | Clock assembly/manufacturing Necklace and pendant manufacturing Jewerly parts manufacturing |
Product manufacturing | Others | Telecommunication equipment manufacturing |
