Most recent update: 2018-06-06
General metal press die( Designing / Mold designing ) |
Company name |
ケー・アイ技術 株式会社 嬉野工場 (Ke- aigijutsu ureshinokoujou) |
Website URL | http://www.kinet.co.jp |
Street address |
Mie Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 95 |
Annual sales | Unregister | EMIDAS Member Number | 71037 |
Type of manufacturing | Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) General metal press die |
Designing | Jig and tool designing | General jig designing Automatic tool designing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Die set machining Bending die Blanking die Forming die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining Injection molding die Insert molding die Below 60 t 60 - 300 t Thermoset resin die Thin wall injection molding die |
Mass production | Metal press | Bending Blanking Forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Plastic | Insert molding PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) Thermoset resin Below 60 t 60 - 300 t Handles small-scale production Thin wall molding |
Surface treatment | Other surface treatment | Shot blast |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press Plastic Measuring |
