CO2 welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Thickness: 3.2 - 9.0 mm( Mass production / Metal press ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Laser processing (longer than 121.2 m)( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Turret punch press processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
株式会社 広伸 (Koushinn) |
Website URL | http://koshin-k.com/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 31,080,000 JPY | Employees | 86 |
Annual sales | EMIDAS Member Number | 70961 | |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Designing | Jig and tool designing | Welding jig designing |
Development and production of prototype/Small-scale production | Machining | Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Plated steel plate Thickness Thickness Thickness Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (200 - 500 t) |
Mass production | Sheet-metal processing | NC set press Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Deburring process Bending process |
Mass production | Welding / welding | CO2 welding Fiber welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Iron Hot-dip galvanizing (mid-size |
Assembly/Inspection | Assembly | Construction component assembly |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Food industry machinery manufacturing Semiconductor manufacturing equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing Sound/fire/water proof material manufacturing Construction machinery manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing Bath products manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking |
Product manufacturing | Others | Transportation equipment manufacturing |
