Most recent update: 2023-09-02
Urethane resin( Mass production / Plastic ) |
Company name |
みのる産業 株式会社 (Minorusanngyou) |
Website URL | https://f-minoru.co.jp/ |
Street address |
Fukui Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 60 |
Annual sales | Unregister | EMIDAS Member Number | 70957 |
Type of manufacturing | Industrial machinery / Electronic parts / Kitchen |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Vacuum injection molding |
Mass production | Plastic | Engineering plastic PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Fluororesin Urethane resin PU (polyurethane) EP (epoxy) |
Mass production | Rubber | Rubber product prototype manufacturing Silicon rubber Urethane rubber Butyl rubber NBR CR EPT Fluoro-rubber Packing-related products Light electrical/earthing rubber Medical |
Surface treatment | Plating/Chemical conversion treatment | Other anti-rust treatments |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Wood coating Electrodeposition coating Electrostatic coating Aqueous coating UV resistant coating Airless spray coating Urethane coating Acrylic coating Ceramic coating Epoxy coating Electrical insulating Heat insulation coating Heat-resistant coating Metal coating |
Surface treatment | Heat treatment | Nitridation |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating Spraying Teflon coating Shot peening/WPC Shot blast Sound blast Etching (surface treatment) Ionized plating Arc spray Plasma spray DLC coating |
Product manufacturing | Production property | Other industrial machinery manufacturing Carrier machine manufacturing Lubrication equipment manufacturing |
