Most recent update: 2023-06-09
NC turning machining( Mass production / Mechanical processing ) |
Machining( Mass production / Mechanical processing ) |
Precision sheet metal processing( Mass production / Sheet-metal processing ) |
Company name |
墨田螺子産業株式会社 (Sumidarashisanngyou) |
Website URL | https://www.sumidams.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 16,000,000 JPY | Employees | 7 |
Annual sales | Unregister | EMIDAS Member Number | 70051 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Hair line machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Arc welding |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Copper Brass Plated steel plate Thickness Single press (200 - 500 t) Progressive press (35 - 80 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Rolling machining Screw cutting machining Iron Stainless Aluminum alloy Copper alloy Molybdenum alloy Sintered metal Automatic screw machining Turning machining(plastic) Casting |
Mass production | Plastic | Extrusion molding Insert molding Outsert molding Air pressure molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic GFRP (glass fiber reinforced plastic) 000 t Injection molding |
Mass production | Sheet-metal processing | Precision sheet metal processing Sheet metal prototype manufacturing Bending process |
Mass production | Welding / welding | Spot welding TIG welding (argon welding) Arc welding fixing with wax |
Assembly/Inspection | Assembly | Industrial machinery assembly Toy and sundries assembly |
Parts manufacturing | Machinery part | Valve manufacturing Connection parts manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Mechanical parts |
Parts manufacturing | Electrical part | Connector manufacturing |
Parts manufacturing | Spring | Terminal spring |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
