Five-face/axes machining( Mass production / Mechanical processing ) |
Large-size plant apparatus manufacturing( Product manufacturing / Plant equipment manufacturing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
NC milling machining( Mass production / Mechanical processing ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Company name | SEIEI CORPORATION. | Website URL | https://mc.metalproc.jp |
Street address |
Fukushima Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 25 |
Annual sales | Unregister | EMIDAS Member Number | 68985 |
Type of manufacturing | Transportation equipment / Machine tools / Industrial machinery |
Large | Medium | Small |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Planer machining Plano miller machining Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Stainless steel Aluminum alloy Machining (resin) Automatic lathe Lathe machining (resin) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing Precision sheet metal machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending (2 m or longer) Bending (hydraulic) 3D pipe machining Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Corner shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Model manufacturing |
Mass production | Metal press | Bending |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Five-face/axes machining Automatic screw machining |
Surface treatment | Coating | Air-spray coating Resin coating Airless spray coating Melamine coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Heat insulation coating Heat-resistant coating Metal coating Fluorine coating |
Surface treatment | Polishing/Lapping | Buffing |
Assembly/Inspection | Repair | Industrial machinery repair |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing Food industry machinery manufacturing Industrial robot manufacturing Environmental equipment manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing Steel and furnace apparatus manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing Large-size plant apparatus manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
