板金加工・製缶加工・マシニング加工などの技術を用い、カーテンウォール用の部品などの建築土木資材を取り扱っております。多業種にわたる産業機器部品も取り扱っており、幅広い分野でご要望にお応えします。
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Construction component assembly( Assembly/Inspection / Assembly ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 エイワ (Eiwa) |
Website URL | https://eiwa01.co.jp/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 15,000,000 JPY | Employees | 37 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 68924 |
Type of manufacturing | Construction material / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Bending die Blanking die Single press die Below 60 t 60 - 300 t Sash molding die |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Plated steel plate Thickness Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Acid pickling Degreasing |
Surface treatment | Heat treatment | Quenching High frequency quenching Carburized quenching |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Shot blast |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
