Most recent update: 2021-08-18
Thickness: 3.2 - 9.0 mm( Mass production / Metal press ) |
Company name |
株式会社 泰成工業所 (Taiseikougyousho) |
Website URL | http://www.taisei-press.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 36,000,000 JPY | Employees | 138 |
Annual sales | Unregister | EMIDAS Member Number | 68483 |
Type of manufacturing | Electrical component for transportation equipment / Industrial machinery / Heavy electric machinery |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Angle machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Shearing (longer than 121.2 m) CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Shaving die Progressive die Transfer press die Single press die Press robot die 60 - 300 t Over 300 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Transfer press (80 - 200 t) Transfer press (200 - 500 t) Press robot (80 -200 t) Press robot (200 - 500 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Zinc (rack) Nickel chromium (rack) |
Surface treatment | Coating | Electrodeposition coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Auto parts assembly Construction component assembly |
