Building materials
Because we combined twill weaving and tatami weaving, parallel wires are secured front and back which created twice more dense than tatami weaving alone.
Tatami weaved net is one of a dense separation net. (tatami weaved net’s meshes of net are showed in 25.4mm spaces between each meshes. The unit is mesh.)
Material: stainless steel, nickel, monel metal, phosphor bronze, etc.
Mesh (LxW): 20×150~510×3600
Diameter (mm): 0.45/0.35~0.025/0.015
Molecule which can pass through (μm): 138~4.0
Thickness (mm): 1.12~0.05
Weight (kg/㎡): 6.6~0.26
●size of open laps of tatami weaving has problem in accuracy, because of a such reason, above sizes and lengths are only good for refencing.
Company name | Okutani Wire Netting MFG Co., Ltd. | EMIDAS Member Number | 64376 |
Koube-shi Chuou-ku Hyogo Japan |
Telephone number | +81-78-351-2531 | Fax number | +81-78-361-1484 |
Employees | 10,000,000 JPY | Annual sales | 1,200,000,000 JPY |
Employees | 63 | Person in charge | 奥谷 忠彦 |
Type of manufacturing | Heavy electric machinery / Construction material / Transportation equipment | ||
Primary clients |
