Most recent update: 2021-05-18
Hot forging ( Mass production / Forging ) |
Company name |
株式会社 小林工具製作所 (Kobayashikouguseisakusho) |
Website URL | http://www.kobayashi-tools.com/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 16,000,000 JPY | Employees | 41 |
Annual sales | 1,800,000,000 JPY | EMIDAS Member Number | 63070 |
Type of manufacturing | Transportation equipment / Jigs and tools / Construction material |
Large | Medium | Small |
Designing | Product and part designing | Gear designing External design |
Designing | Jig and tool designing | General jig designing General-purpose jig designing |
Designing | Test | Destructive test Investigative research |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Sintered metal Broaching Casting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Prototype/Small-lot molding |
Mass production | Metal press | Bending Blanking Coining Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Thickness Diameter Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Mechanical processing | Gear cutting machining Screw cutting machining Iron Stainless Copper alloy Nickel alloy Molybdenum alloy Broaching machining Casting |
Mass production | Forging | Hot forging Cold forging Drop hammer Iron Others 500 g - 5 kg |
Surface treatment | Polishing/Lapping | Tool polishing Blade polishing Buffing |
Surface treatment | Heat treatment | Quenching |
Surface treatment | Other surface treatment | Buffing Shot blast |
Assembly/Inspection | Assembly | Auto parts assembly Construction component assembly Toy and sundries assembly |
Assembly/Inspection | Inspection | Metal press Forging |
Parts manufacturing | Machinery part | Gear manufacturing Crank shaft manufacturing pipe manufacturing |
Parts manufacturing | Other parts | Blade manufacturing |
Auto parts manufacturing | Drive system part | Accelerator Clutch Transmission Drive shaft Caliper Brake parts |
Auto parts manufacturing | Engine | Fuel system |
Product manufacturing | Production property | Other industrial machinery manufacturing Blade manufacturing |
