Most recent update: 2023-03-01
弊社は千葉県で1973年の設立からニッケル合金などの機高能材を中心に製造している金属材料メーカー
ニッケル合金などの機能性金属材料なら弊社におまかせください!
rolling( Material / Nonferrous metal distribution ) |
Company name |
株式会社日本クロス圧延 (Kabushikigaishanihonnkurosuatsuenn) |
Website URL | https://www.atuen.com/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 25,000,000 JPY | Employees | 35 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 58737 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment |
Large | Medium | Small |
Material | Steel component distribution | Stainless steel Shaped stainless steel Stainless steel spring Cold-rolled steel plate Spring steel Flat steel plate Wires Railroad track Other shaped steel bars rolling |
Material | Specialized material distribution | 42 alloy Kovar Phosphor bronze Clad steel Molybdenum alloy Tantalum Nickel chromium alloy Magnetic steel sheet rolling |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Titanium Nickel Magnesium Coils Others rolling |
Development and production of prototype/Small-scale production | Machining | Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Titanium |
Development and production of prototype/Small-scale production | Sheet-metal processing | Swaging |
Mass production | Metal press | Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Nickel Thickness Thickness Thickness Thickness Beryllium copper |
Mass production | Forging | Hot forging Cold forging Below 500 g 500 g - 5 kg Over 5 kg |
Mass production | Casting | Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Copper Brass Aluminum Stainless steel Titanium Magnesium |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Air quenching Solution heat treatment |
Surface treatment | Other surface treatment | Shot blast Sound blast Glass beads blast Etching (surface treatment) |
Auto parts manufacturing | Interior part | Audio components |
Product manufacturing | Plant equipment manufacturing | Hydro/thermal/electric/atomic power generation apparatus manufacturing |
