Most recent update: 2024-03-28
創業以来60年以上小物精密加工一筋に油圧、高速オフ印、工作機械と時代のニーズに即した事業に邁進して参りました。CNC複合加工でお困りの際はお気軽にお問い合わせ下さい。
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
オリオン精密株式会社 (Orionnseimitsu) |
Website URL | https://www.orion.gr.jp/ |
Street address |
Yamagata Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 20 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 5643 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Sintered metal Sintered metal Keyway milling Automatic lathe Bench lathe machining Router machining Milling (resin) Lathe machining (resin) Casting Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Centerless grinding |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Chromium (rack) Black chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Parkerizing (phosphate film) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Titanium Degreasing Black oxide finish Colored alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
