Prototype/Small-lot molding( Development and production of prototype/Small-scale production / Prototype processing ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 ウシオ (Ushio) |
Website URL | http://www.ushio-net.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 5629 |
Type of manufacturing | Home electrical appliances / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Automatic lathe Brass |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Deburring 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining Etching Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum Precision cutting |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Fused Deposition Molding (FDM) Prototype/Small-lot molding |
Die manufacturing | Press die | Part processing Drawing die Bending die Blanking die Single press die |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Nickel (rack) Copper (rack) Gold/Silver plating Alumite (anode oxidation) Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel Black oxide finish Black chromate (black/green) Black nickel |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Battery spring Spring washer Stainless steel |
