Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Chromium (rack)( Surface treatment / Plating/Chemical conversion treatment ) |
Colored chromate (multi-color)( Surface treatment / Plating/Chemical conversion treatment ) |
Unichromate (white)( Surface treatment / Plating/Chemical conversion treatment ) |
CO2 welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Plated steel plate( Mass production / Metal press ) |
Company name |
株式会社 佐竹製作所 (Satakeseisakujo) |
Website URL | https://www.satake-ss.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 22,400,000 JPY | Employees | 30 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 5578 |
Type of manufacturing | Construction material / Transportation equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Mass production | Metal press | Bending Blanking Iron Stainless steel Brass Plated steel plate Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Zinc (barrel) Chromate (general) Nickel (rack) Copper (rack) Chromium (rack) Zinc (rack) Trivalent Chromate (barrel plating) Iron Brass Unichromate (white) Colored chromate (multi-color) |
