NC turning machining( Mass production / Mechanical processing ) |
Gear cutting machining( Mass production / Mechanical processing ) |
Rolling machining( Mass production / Mechanical processing ) |
Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Keyway milling( Development and production of prototype/Small-scale production / Machining ) |
Deep hole drilling( Development and production of prototype/Small-scale production / Machining ) |
Company name | Akiyama Manufacturing Co., Ltd. | Website URL | http://www.akiyama-ss.co.jp/ |
Street address |
Kumagaya Saitama Japan
[See map] |
Person in charge | |
Telephone number | +81-48-523-1059 | Fax number | +81-48-523-1060 |
Capital | 30,000,000 JPY | Employees | 72 |
Annual sales | 740,000,000 JPY | EMIDAS Member Number | 5568 |
Type of manufacturing | Industrial machinery / Transportation equipment | ||
Main 3 products |
Primary clients |
PR message
Our factory specializes in crank shaft and shaft processing for automobiles, compressors, motors, pumps and much more. We can handle all sorts of products with a circumference of Φ15 - Φ100, a length of 70 - 500 mm and a hole in the center. We can handle the entire production process from adjusting materials to final product delivery for one or two prototypes or mass production lots of 10,000 units. Leave any sort of shaft or crank shaft processing to us.
A video is available at our company's website showing our crank shaft production process.
Most recent update:2022-07-14
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Nickel alloy Molybdenum alloy Sintered metal Keyway milling Automatic lathe Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Profile grinding |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Mass production | Mechanical processing | Machining NC turning machining Gear cutting machining Rolling machining Iron Stainless Nickel alloy Molybdenum alloy Casting |
Mass production | Forging | Hot forging Cold forging Press forging Drop hammer Iron |
Mass production | Casting | Cast-iron Ductile cast iron |
Surface treatment | Plating/Chemical conversion treatment | Electroless nickel (barrel) Electroless nickel (rack) Hard chromium (rack) |
Surface treatment | Coating | Electrodeposition coating Electrostatic coating |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Vacuum quenching High frequency quenching Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing Sound blast |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
