Most recent update: 2023-09-18
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 ツカタ (Tsukata) |
Website URL | http://www.tsukata.co.jp |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 44 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 5546 |
Type of manufacturing | Machine tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Blank cutting | Laser marking Shirring Fiber laser processing Clean cut stainless |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Aldine treatment (aluminum chromate) Electroless nickel (rack) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Degreasing Colored alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Air-spray coating Powder coating Electrodeposition coating Electrostatic coating Melamine coating Acrylic coating Lacquer coating Epoxy coating Metal coating |
Surface treatment | Printing and others | Silk screen printing |
Assembly/Inspection | Assembly | Precision equipment assembly |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Measurement/testing devices manufacturing Chemical industry machinery and equipment manufacturing Industrial robot manufacturing Semiconductor manufacturing equipment manufacturing |
