Most recent update: 2022-09-01
Company name |
福助機工 株式会社 (Fukusukekikou) |
Website URL | http://www.fukusukekikou.co.jp |
Street address |
Hyogo Japan
[See map] |
Person in charge | - |
Capital | 31,480,000 JPY | Employees | 130 |
Annual sales | Unregister | EMIDAS Member Number | 5354 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Deep hole drilling Gear hobber Profile milling Spinning Iron Stainless steel High rigid material Copper alloy Titanium alloy Molybdenum alloy Ceramic Machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing Hot forging die Press forging die |
Die manufacturing | Casting die | Designing Manufacturing Die-casting die Shell moulding die Lost-wax casting die Sand casting die |
Mass production | Forging | Hot forging Press forging |
Mass production | Casting | Shell moulding Lost-wax Centrifugal casting Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy Copper alloy Zinc alloy |
Surface treatment | Printing and others | Engraving |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Vacuum quenching Flame quenching Solution heat treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Spraying |
