Most recent update: 2022-09-21
Company name |
株式会社 ミノル (Minoru) |
Website URL | http://www.mi-no-ru.co.jp/ |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 30 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 5306 |
Type of manufacturing | Measuring machinery / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing NC set press Precision sheet metal machining Angle machining Mirror surface machining Bending (hydraulic) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Assembly/Inspection | Assembly | Industrial machinery assembly |
