Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社ゼン (Zenn) |
Website URL | https://www.zen.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 45,000,000 JPY | Employees | 60 |
Annual sales | Unregister | EMIDAS Member Number | 5288 |
Type of manufacturing | Jigs and tools / Office automation equipment / Office appliances |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Gear hobber Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Machining (resin) Bench lathe machining Lathe machining (resin) Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Bending Small-size prototype manufacturing Vacuum injection molding Fused Deposition Molding (FDM) Powder sintering Molten resin method Simplified/Molding prototype mold |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing |
Mass production | Plastic | Vacuum molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin Urethane resin Elastomer Injection molding PES (polyethersulfone) EP (epoxy) |
Mass production | Rubber | Rubber product prototype manufacturing |
Surface treatment | Coating | Air-spray coating Urethane coating Lacquer coating |
Surface treatment | Printing and others | Engraving Silk screen printing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
Assembly/Inspection | Inspection | Measuring |
