Tin (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Gold/Silver plating( Surface treatment / Plating/Chemical conversion treatment ) |
Electroless nickel (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Zinc (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Alumite (anode oxidation)( Surface treatment / Plating/Chemical conversion treatment ) |
Chromium (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
60 - 300 t( Mass production / Plastic ) |
Injection molding ( Mass production / Plastic ) |
Company name | Mitaka Electric Co.,Ltd | Website URL | http://www.mtkd.co.jp/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 57 |
Annual sales | Unregister | EMIDAS Member Number | 5278 |
Large | Medium | Small |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Progressive die Transfer press die Single press die |
Mass production | Metal press | Single press (80 - 200 t) Progressive press (80 - 200 t) |
Mass production | Plastic | Insert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic Thermoset resin Urethane resin Below 60 t 60 - 300 t Injection molding PES (polyethersulfone) EP (epoxy) |
Mass production | Rubber | Compression molding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) |
