Most recent update: 2024-02-10
NC cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
NC internal grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Shaft and roller manufacturing( Parts manufacturing / Machinery part ) |
Company name |
有限会社 頼鉄工所 (Yoritekkousho) |
Website URL | https://www.yori-tekko.jp/ |
Street address |
Okayama Japan
[See map] |
Person in charge | - |
Capital | 8,700,000 JPY | Employees | 23 |
Annual sales | EMIDAS Member Number | 5262 | |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Molybdenum alloy Keyway milling Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig grinding Internal grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Friction welding |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Normalizing Annealing Stress relief annealing (SR treatment) Quenching Salt bath quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing Shot blast |
Parts manufacturing | Machinery part | Valve manufacturing Bearing manufacturing Vacuum components manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Fluid equipment manufacturing Environmental equipment manufacturing Blade manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
