Most recent update: 2024-02-19
Company name |
いわき鉄工 株式会社 (Iwakitekkou) |
Website URL | http://ww5.et.tiki.ne.jp/~iwaki/ |
Street address |
Fukushima Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 20 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 5148 |
Type of manufacturing | Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Keyway milling Automatic lathe Shaper machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing 3-roll bending (2 m or longer) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Bending die Over 300 t |
Die manufacturing | Casting die | Manufacturing Die-casting die Sand casting die |
Mass production | Casting | Gravity casting Aluminum alloy 500 g and below Over 500 g and less than 5 kg |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Lubrication equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing |
