Most recent update: 2024-01-10
Company name |
株式会社 伊藤製作所 (Itouseisakusho) |
Website URL | http://www.ito-seisakusho.co.jp/ |
Street address |
Yamagata Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 60 |
Annual sales | Unregister | EMIDAS Member Number | 5129 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Jig boring Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Electroless nickel (rack) |
Surface treatment | Coating | Electrodeposition coating |
Surface treatment | Polishing/Lapping | Chemical polishing |
Surface treatment | Printing and others | Printing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Air quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating Buffing Shot blast Sound blast |
