Most recent update: 2011-08-18
Part processing( Die manufacturing / Press die ) |
Company name |
株式会社インデックス (Inndekkusu) |
Website URL | http://www.index-j.co.jp/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 42 |
Annual sales | 1,900,000,000 JPY | EMIDAS Member Number | 49675 |
Type of manufacturing | Jigs and tools / Machine tools / Measuring machinery |
Large | Medium | Small |
Material | Steel component distribution | Heavy plate Stainless steel Shaped stainless steel Free-machining steel Flat steel plate Steel (round) bar Steel castings |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes |
Material | Plastic material distribution | Urethane resin |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Machining (resin) Sintered metal Sintered metal Keyway milling Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Form grinding Jig boring Internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing |
Die manufacturing | Press die | Part processing Plate machining Die set machining |
Die manufacturing | Plastic mold | Part processing Plate machining Mold base machining |
Die manufacturing | Casting die | NC data creation |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Five-face/axes machining Wire machining Electrical discharge machining Spinning Iron Stainless Cemented carbide Aluminum alloy Copper alloy Ceramic Sintered metal Turning machining(plastic) Casting |
Mass production | Casting | Cast-iron Cast steel |
Surface treatment | Plating/Chemical conversion treatment | Electroless nickel (barrel) Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Polishing/Lapping | Mirror polishing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Coating DLC coating |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Shaped spring Conical spring Spring washer |
