Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Internal grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Thread grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Shaft and roller manufacturing( Parts manufacturing / Machinery part ) |
Company name |
株式会社 浅田精機 (Asadaseiki) |
Website URL | http://www.asadaseiki.jp |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 36,250,000 JPY | Employees | 62 |
Annual sales | Unregister | EMIDAS Member Number | 48713 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Keyway milling Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig boring Jig grinding Internal grinding Thread grinding NC internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Die manufacturing | Plastic mold | Part processing |
Surface treatment | Plating/Chemical conversion treatment | Black oxide finish |
Surface treatment | Heat treatment | Normalizing Annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Flame quenching Sub-zero treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Precision equipment assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
