Most recent update: 2022-06-30
Laser processing (longer than 121.2 m)( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending (over 3.0 m)( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 三和製作所 (Sannwaseisakusho) |
Website URL | http://www.sanwa-3355.co.jp/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 15,500,000 JPY | Employees | 60 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 48622 |
Type of manufacturing | Construction material / Office appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Mass production | Metal press | Bending Blanking Roll forming Iron Stainless steel Aluminum Copper Plated steel plate Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Single press (below 80 t) Single press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Iron Aluminum Stainless steel Unichromate (white) Colored chromate (multi-color) |
Assembly/Inspection | Assembly | Construction component assembly |
