Most recent update: 2015-10-01
Hot forging ( Mass production / Forging ) |
Company name |
株式会社 川口鍛工所 (Kawaguchitannkoujo) |
Website URL | http://kawa-tan.com/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 25,000,000 JPY | Employees | 34 |
Annual sales | Unregister | EMIDAS Member Number | 47676 |
Type of manufacturing | Transportation equipment / Industrial machinery / Machine tools |
Large | Medium | Small |
Designing | Mold designing | Forging die designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Titanium alloy Nickel alloy Keyway milling Automatic lathe Shaper machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Gear grinding |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing Hot forging die Press forging die |
Mass production | Forging | Header machining Hot forging Cold forging Press forging Drop hammer Iron Others Below 500 g 500 g - 5 kg Over 5 kg Ring forging |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Chromium (rack) Zinc (rack) Acid pickling Iron Stainless steel Other anti-rust treatments Hard chromium (rack) Black oxide finish Unichromate (white) |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
Assembly/Inspection | Inspection | Forging |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Bolt manufacturing |
