Most recent update: 2022-11-14
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name |
株式会社 コーシン (Ko-shinn) |
Website URL | http://www.k-koshin.com/ |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 47591 |
Type of manufacturing | Industrial machinery / Kitchen / Medical equipment |
Large | Medium | Small |
Designing | Product and part designing | External design |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | Spinning Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting 3D laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Stud welding Capacitator spot welding YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness φ0.6mm - φ9.0mm Single press (below 80 t) |
Surface treatment | Polishing/Lapping | Electropolishing Buffing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing |
