Metallic mesh manufacturing( Parts manufacturing / Other parts ) |
Wires( Material / Steel component distribution ) |
Spot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Pipe bending( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Construction and civil engineering material manufacturing( Product manufacturing / Construction and civil engineering machinery manufacturing ) |
Construction component assembly( Assembly/Inspection / Assembly ) |
Office equipment assembly( Assembly/Inspection / Assembly ) |
Stud welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name | Takaoka Cage Industry Co. | Website | http://www.t-cage.co.jp/ |
Street address |
Toyama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 50 |
Annual sales | 1,500,000,000 JPY | EMIDAS Member Number | 47544 |
Large | Medium | Small |
Designing | Product and part designing | Office equipment designing |
Material | Steel component distribution | Perforated metal Expanded metal Steel (round) bar Wires |
Material | Nonferrous metal distribution | Others Steel (round) bar Copper and brass products Titanium |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Pipe bending Coating Bending (hydraulic) Pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Corner shearing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing Welding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Stud welding Brazing Robot welding Arc welding TIG welding (argon welding) CO2 welding Spot welding |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Acid pickling Copper (rack) Gold/Silver plating Chromium (rack) Nickel chromium (rack) |
Surface treatment | Coating | Heat-resistant coating Airless spray coating Air-spray coating Powder coating Electrodeposition coating Resin coating Melamine coating Urethane coating Acrylic coating Ceramic coating |
Surface treatment | Polishing/Lapping | Chemical polishing Electropolishing |
Surface treatment | Other surface treatment | Coating Buffing |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
Parts manufacturing | Other parts | Metallic mesh manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Food industry machinery manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing |
