Most recent update: 2015-10-01
Nickel ( Material / Nonferrous metal distribution ) |
Company name |
株式会社 オーサカステンレス (Oosakasutennresu) |
Website URL | http://www.osc21.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 42 |
Annual sales | 3,000,000,000 JPY | EMIDAS Member Number | 47382 |
Large | Medium | Small |
Designing | Test | Nondestructive test Chemical analysis |
Material | Steel component distribution | Stainless steel Steel (round) bar Wires |
Material | Nonferrous metal distribution | Titanium Nickel |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Keyway milling Automatic lathe Bench lathe machining Shaper machining Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding Internal grinding Centerless grinding Thread grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Arc welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Mass production | Forging | Header machining Hot forging Cold forging Warm forging Ring forging Free forging |
Surface treatment | Plating/Chemical conversion treatment | Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Iron Stainless steel Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Polishing/Lapping | Electropolishing Buffing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Straightening annealing Vacuum annealing Quenching Vacuum quenching Austempering High frequency quenching Flame quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Assembly/Inspection | Inspection | Bolt/Screw/Nut Measuring |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Switch manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Stamp manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
