Most recent update: 2018-01-09
Company name |
株式会社 プラストワーク (Purasutowa-ku) |
Website URL | http://www.plastwork.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 45,000,000 JPY | Employees | 30 |
Annual sales | 400,000,000 JPY | EMIDAS Member Number | 47245 |
Type of manufacturing | Home electrical appliances / Audio-video equipment / Office automation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Machining (resin) Bench lathe machining Milling (resin) Lathe machining (resin) Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Hair line machining |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Water jet cutter machining CO2 laser machining Laser marking |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Bending Small-size prototype manufacturing Chassis prototype manufacturing Vacuum injection molding Model manufacturing Prototype/Small-lot molding Small-lot/Injection molding |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Aluminum Colored alumite |
Surface treatment | Coating | Air-spray coating Resin coating Urethane coating Acrylic coating Lacquer coating |
Surface treatment | Printing and others | NC engraving Engraving Silk screen printing Pad printing Hot stamping (gold embossing) Laser engraving Direct printing |
Surface treatment | Other surface treatment | Vacuum deposition Spattering Glass beads blast |
