Most recent update: 2023-09-15
Fiber welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name |
有限会社 堀本精工 (Horimotoseikou) |
Website URL | https://www.horimoto-seiko.co.jp/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 40 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 47100 |
Type of manufacturing | Machine tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Keyway milling Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Five-face machining Combined lathe machining Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Corner shearing CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Jig boring |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding Capacitator spot welding YAG laser machining Fiber welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Single press die Below 60 t |
Mass production | Metal press | Drawing Bending Blanking Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Diameter Single press (below 80 t) |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Buffing |
Parts manufacturing | Spring | Thin leaf spring |
