Most recent update: 2022-02-07
Company name |
株式会社 ワカタ製作所 (Wakataseisakusho) |
Website URL | http://www.wakata.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 8 |
Annual sales | Unregister | EMIDAS Member Number | 47093 |
Type of manufacturing | Industrial machinery / Machine tools / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing NC data creation 3D modeling Drawing die Bending die Blanking die Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Plated steel plate Stainless steel material for spring Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromium (barrel) Chromate (general) Nickel (rack) Chromium (rack) Nickel chromium (rack) Acid pickling Trivalent Chromate (barrel plating) Iron Hard chromium (rack) Black oxide finish Unichromate (white) Colored chromate (multi-color) |
Surface treatment | Coating | Electrodeposition coating |
