Most recent update: 2017-09-27
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
有限会社 伊藤プレス工作所 (Itoupuresukousakusho) |
Website URL | http://www.ito-puresu.jp |
Street address |
Ehime Japan
[See map] |
Person in charge | - |
Capital | 12,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 46934 |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die NC data creation (press) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Deep hole drilling Gear hobber Thread-cutting Profile milling Straightening Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Broaching Keyway milling Automatic lathe Shaper machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining NC vertical lathe Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding NC internal grinding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Printing and others | NC engraving Engraving |
