Most recent update: 2022-08-23
Company name |
宏明技研 有限会社 (Koumeigikenn) |
Website URL | https://koumei-dream.jp/ |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 22 |
Annual sales | 520,000,000 JPY | EMIDAS Member Number | 46746 |
Type of manufacturing | Telecommunication equipment / Kitchen / Construction material |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | High-frequency welding |
Development and production of prototype/Small-scale production | Prototype processing | Fused Deposition Molding (FDM) |
Die manufacturing | Plastic mold | Injection molding die |
Die manufacturing | Rubber mold | Rubber mold part processing Part processing Blanking die |
Die manufacturing | Powder metallurgy mold | Manufacturing Powder metallurgy mold part manufacturing |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Die manufacturing | Casting die | Wooden model |
Mass production | Plastic | Insert molding Outsert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer 60 - 300 t 000 t Injection molding EP (epoxy) |
Mass production | Rubber | Compression molding Blanking Silicon rubber Urethane rubber Butyl rubber NBR SBR CR EPT Packing-related products Home electrical appliances Sundries and shoes |
Mass production | Powder metallurgy | Metal Below 500 g 500 g - 5 kg Over 5 kg |
Mass production | Forging | Press forging Aluminum Brass 500 g - 5 kg |
Mass production | Casting | Lost-wax Cast steel Zinc alloy 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Chromium (barrel) Gold/Silver plating |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating |
Surface treatment | Printing and others | Printing Silk screen printing |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring |
Parts manufacturing | Other parts | Lock manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
