1957年の創業当時よりアルミニウム材料販売問屋の先駆けとしてお客様のお役にたつべく励んでまいりました。アルミの素晴らしい特性を最大限に引き出し今後もより一層、お客様のお役に立つプロ集団を目指します。
Aluminum extrusions( Material / Nonferrous metal distribution ) |
Aluminum alloy( Development and production of prototype/Small-scale production / Casting ) |
Pipe material( Material / Nonferrous metal distribution ) |
rolling( Material / Nonferrous metal distribution ) |
Chequered plate( Material / Steel component distribution ) |
Flat steel plate( Material / Nonferrous metal distribution ) |
Perforated metal( Material / Steel component distribution ) |
Company name |
ニッカル商工 株式会社 (Nikkarushoukou) |
Website URL | http://www.nikkal.net/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 60,000,000 JPY | Employees | 23 |
Annual sales | 1,250,000,000 JPY | EMIDAS Member Number | 46730 |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Material | Steel component distribution | Perforated metal Expanded metal Chequered plate |
Material | Specialized material distribution | Phosphor bronze |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products Titanium Pipe material Coils Others rolling Aluminum extrusions |
Development and production of prototype/Small-scale production | Machining | Thread-cutting Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Copper alloy Simultaneous 5-axis machining Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Shearing (longer than 121.2 m) Water jet cutter machining Corner shearing CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Aluminum die-casting |
Development and production of prototype/Small-scale production | Casting | Lost wax Sand casting Aluminum alloy |
Mass production | Metal press | Aluminum Copper |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Complex turning machining Wire machining Screw cutting machining Stainless Aluminum alloy Copper alloy Magnesium alloy Automatic screw machining Seamless Ultra-thin High precision High strength |
Mass production | Plastic | Injection molding |
Mass production | Casting | Aluminum alloy |
Mass production | Sheet-metal processing | Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Bender processing (flood control) Bending process |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Aluminum |
Surface treatment | Coating | Melamine coating Acrylic coating Fluorine coating |
Surface treatment | Other surface treatment | Sound blast Etching (surface treatment) |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing Chemical industry machinery and equipment manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Furniture/Interior | Cabinetmaking |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing Energy-saving fishery machinery manufacturing Energy-saving livestock-farming machinery manufacturing Other food industry machinery manufacturing |
